Old 02-09-2016, 06:45 PM   #1
terry1
Liked 24 Times in 13 Posts
Smile Corvette clutch linkage parts.
Looking for a source of Corvette clutch linkage parts for my '78 Camaro.
Got the fork and push rod a while back but don't remember where(65+)!!!
Having a bit of an issue with geometry.
Terry K
terry1 is offline   Reply With Quote
Old 02-09-2016, 07:36 PM   #2
L79racer
L79racer's Avatar
Default Re: Corvette clutch linkage parts.
long island corvette supply
L79racer is offline   Reply With Quote
Old 02-10-2016, 01:23 AM   #3
Greg Barsamian
Liked 427 Times in 97 Posts
Corvette Clutch Fork GM Part # 3887177
Aftermarket Clutch Linkage Rod: Mr. Gasket # 2478-Discontinued
Danchuck Clutch Rod Kit #244
Adjustable Clutch Fork Pivot Ball: Lakewood Part # 15501
Greg Barsamian is online now   Reply With Quote
Old 02-11-2016, 11:11 AM   #4
terry1
Smile Re: Corvette clutch linkage parts.
Is the length of the Corvette clutch cross shaft(Z bar) the same length as a Camaro one; considering all being the same year?
Terry K
Old 02-11-2016, 12:22 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Terry K
No. Using the Corvette fork with tubular rods with Heim joints in the ends makes for good linkage.
Old 02-11-2016, 01:33 PM   #6
terry1
Thanks Dwight. Would you have a picture of your set up?
Terry K
Old 02-11-2016, 02:31 PM   #7
Dwight Southerland
Assuming you have the Corvette fork that looks like this:
You have to cut material away from the end to make the slot wide enough for a 3/8" Heim joint to slide in so you can put a pin through the holes in the fork and the joint. You should be able to figure out how to make your stuff fit from there. Here's a picture I found on the internet that shows some linkage rods with Heim ends.
Rather than mess with the steel pieces and welding a stuff, the last setup I made used 5/8" x .125" wall aluminum tube. Much easier. Cut to length and thread the inside (you will need right and left hand 3/8-24 taps). Works good.
Old 02-11-2016, 04:18 PM   #8
4543
Liked 649 Times in 140 Posts
Uptmore corvette parts China spring Texas. Large all corvette wrecking yard.
4543 is offline   Reply With Quote
Old 02-12-2016, 07:03 PM   #9
NHRA 303
NHRA 303's Avatar
They seem a little pricey. But by the time you buy the lt. and rt. taps it might all work out. Ive been running this for a few years with out any issues. Very easy when it come to making adjustments.
Hope this helps.
Steve
http://cmc.speeddirect.com/itemdesc....05-125&eq=&Tp=
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
