#61 |
Liked 184 Times in 113 Posts
These are what I found TPI Intakes and runners
The following airflow tests were performed on the University of Northwestern Ohio's SuperFlow SF600 Flow Bench. All CFM values are corrected for airflow at 28 inches of water. Injector flow rates are flowed at 43.5 PSI on an injector flow bench using test fluid with same density as gasoline. AirFlow Stock TPI/LT1 48mm Throttle Body w/o airfoil -- 783.0 cfm Stock TPI/LT1 48mm Throttle Body w/ airfoil -- 821.9 cfm TPI/LT1 52mm Throttle Body w/o airfoil -- 848.9 cfm TPI/LT1 52mm Throttle Body w/ airfoil -- 898.8 cfm Stock 98 Camaro 3800 II Throttle Body -- 554.3 cfm Stock TPI Bosch MAF sensor w/ screens -- 517.8 cfm Stock TPI Bosch MAF sensor w/o screens -- 658.4 cfm Stock 87 GN 3.8L Turbo AC MAF sensor w/ screen -- 584.2 cfm Stock 86 2.8L AC 5-wire MAF sensor w/ screen -- 576.2 cfm Stock 96-up AC 3100 V6 MAF sensor w/ screen -- 616.4 cfm Stock 96-up AC 3100 V6 MAF sensor w/o screen -- 670.7 cfm Stock 94-up LT1 MAF Sensor w/o screen -- 719.0 cfm Stock 85-87 Firebird TPI airbox mid piece -- 499.3 cfm Stock 4.3/5.0/5.7 2bbl TBI complete -- 574.1 cfm (dry) Stock 4.3/5.0/5.7 2bbl TBI w/o injectors -- 584.7 cfm Stock 3800 vin L throttle body w/ screen -- 419.1 cfm Stock 3800 vin L throttle body w/o screen -- 444.8 cfm 4bbl MPFI Holley Throttle Body -- 1287.6 cfm Last edited by Dan Fahey; 03-11-2016 at 12:04 PM. |
#62 |
From same web page
Flow (cfm) Max. NA HP Stock 668 300 Stock w/airfoil 710 350 52MM w/airfoil 835 400 54MM (AS&M) 900 450 58MM 1050 500 |
#63 |
Liked 32 Times in 19 Posts
Great info. Any track confirmation A.B.A?
#64 |
#65 |
Carburetors are not rated at that high of a test pressure. Raise that, cfm goes up.
Flow a 750 cfm Holley or Quadrajet carb ar 28", it will show MUCH more than 750 cfm. 28" is for cylinder heads.
Ed Wright 4156 SS/JA |
#66 |
28" vacuum is standard = 1.01 lbf/ inch squared
#67 |
It is the standard for CYLINDER HEADS! And, not all shops even use that.
When did you get your first flow bench? Over 30 years ago here. 2 & 4 barrels carbs are not even rated at the same depression. To compare them to carburetors, they would have to be flowed at the same depression.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 03-11-2016 at 07:01 PM. |
#68 |
Liked 124 Times in 39 Posts
My cfm measurement is the timeslip! :-)
Sean Cour T6066 ladle |
#69 |
But, we don't know as much as the office guy above. He has Google.
#70 | |
Liked 805 Times in 245 Posts
This sounds like a lot of fun, do you think we can make this happen? I'll reinstall my rear view mirrors and get some new brake pads... Jim Caughlin SS 6019 |
