Old 03-22-2016, 06:19 AM   #1
joespanova
Liked 13 Times in 11 Posts
Default Re: Oil starvation issues SBC HELP?
Originally Posted by L79racer View Post
What crank is in your motor? I had a very similar problem. ruined motor twice. Kept loosing pressure. Thought it was aerating oil. Tried more, then less oil. changed pump, pickups, restrictors no restrictors etc. Finally got new crank and it solved the problem. I had an eagle crank that was crossed drilled from 2006. Machine shop said that they didnt do that anymore. New eagle crank and no more problem. Sounds crazy but everything else in motor was exactly the same.
Its a BRC 4340 3.48 crank.
Its not cross drilled.
It seems like the answer is:
Std pressure pump.
A well thought out windage tray / pump baffle.
Reduce vac pump vac level.
and for me anyway , adding an accumulator just because.
I'm pretty sure the first 2 are the "focal point" for any good SS engine.
Old 03-22-2016, 08:20 PM   #2
Fred D Bartoli
Carl
Happened to notice your post about excessive bleed off with cam bearings with (3) holes. I am not a professional engine builder but I do build the motors for our super stock cars. I currently have (3) motors, (1) Dart and (2) bow-tie blks. all (3) blks. have Dura bond bearings with (3) holes. I have not had any issues with them. Just wondering how you are determining excessive bleed off, is there a specific test?. How must bleed off is considered excessive?
Fred D Bartoli is offline   Reply With Quote
Old 03-23-2016, 05:56 AM   #3
joespanova
Originally Posted by Fred D Bartoli View Post
Carl
Carl seems to be the only one that really cares about this..........
Old 03-23-2016, 06:54 AM   #4
Chuck Westcott
Chuck Westcott's Avatar
Call Tony @ Dart-- Ask Him about Oil restricters recommendations for your block. If your not using any at all your flooding the top end of your .engine and starving the bottom end. Remember Dart blocks have restricters front and rear.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 03-23-2016, 08:53 AM   #5
joespanova
I DID use oil restrictors in my old Gen 1 blocks and had the same oil starvation results.
Even though this block has a different style of restriction ( drilled plug ) I was advised against using them. So I didn't.
But regardless , the result in the Gen 1 block ( with restrictors ) was the same oil stavation issue
Old 03-23-2016, 09:11 AM   #6
Ed Wright
Ed Wright's Avatar
How do you check the gap between the oil pump pickup & The bottom of the pan?
Do not just assume it's correct, and just bolt it together. I have had to cut & re-weld the support on the pickup before to correct it.
You are doing something seriously wrong.
And Carl isn't the only one concerned about the 3 hole cam bearings.
Ed Wright 4156 SS/JA
Old 03-23-2016, 09:45 AM   #7
joespanova
C' mon Ed.......I realize you dont know me.....but.....
Of course I check it!........either assembly is bolted to cap straight edge to pan rail , same on pan or I use clay...........same way you and everyone else check it.
Let me ask you this........
Tell me about your 8800 plus......... wet sump combo.
And I'm not being sarcastic..........tell me about your best small block wet sump setup , ring pack , comp. , and whether or not you used a vac pump.
I'm all ears. And NO..............I'm not doing something seriously WRONG. Its more like the effect of what I'm doing...........neither right nor wrong..........just an evolution towards a solution . If you follow these posts you'll conclude many engine builders and racers have experienced similar issues with oil problems and found the solutions. Kinda makes ya wonder how guys moved into dry sumps and WHY in the first place many moons ago.
But I know a wet sump will work..............and thats why I asked here , on a Super Stock forum , because I know the RPM ranges are in my wheelhouse and its done everyday. I made a mistake with vac , learned the value of pan and tray design and pumps..................whaddya want me to say?
Old 03-23-2016, 09:17 AM   #8
carl hinkson
Liked 18 Times in 10 Posts
The Sportsman blocks are different then the Billet cap blocks, I would not use restrictors with roller lifters as the lifters bore clearance is what allows oil to the push rods, The oil holes are on the side of the lifter and not in the oil band. Restricting oil may burn up the push rods.
carl hinkson is offline   Reply With Quote
Old 03-23-2016, 09:26 AM   #9
Chuck Westcott
Originally Posted by carl hinkson View Post
The Sportsman blocks are different then the Billet cap blocks, I would not use restrictors with roller lifters as the lifters bore clearance is what allows oil to the push rods, The oil holes are on the side of the lifter and not in the oil band. Restricting oil many burn up the push rods.
I believe Dart recommends Drilled Restricter plugs in both front and rear .250 hole size. that should allow plenty of pressurized oil flow to the top end and yet adequate pressurized flow to the bottom end.
Old 03-23-2016, 09:32 AM   #10
joespanova
Like Carl said............the Little M ( sportsman ) only restricts at the rear......similar to a Gen 1 but a different style restrictor.
