Old 04-07-2016, 06:04 AM   #1
Dick Butler
Liked 32 Times in 19 Posts
Default Re: motor home safety
New tires (bridge stones) definitely show much softer ride. Confirms old tires were stiffening or harder w age. Load range G I believe
Old 04-07-2016, 07:25 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,247 Times in 987 Posts
Goodyear Marathons are absolute junk (fortunate one blowout north of Atlanta on I-75 wasn't a bigger disaster)...MAXXIS makes several good alternatives with higher load rating if you don't want to resort to LT tires for whatever reason. Just bought a MH with Goodyears and will be switching to Michelins at first opportunity (after Uncle Sam gets his check of course).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-07-2016, 08:29 AM   #3
mykids
Liked 2 Times in 1 Post
If you are planning on going through Massachusetts this summer with your Coach and a trailer in tow - my best friend had to attend a DOT safety meeting for the construction company he work's for and the DOT officer brought up Motor Homes and said there intent was to have a DOT officer parked before the weigh stations and directing you to go to the weigh station ( even though you are not mandated to do so) - they will then conduct a modified DOT check up for proper air pressure - lights - tire condition - safety chains - I am sure being Drag Racers we all leave home with clean rig's as I have always told my son to run with the lights on and make sure it was washed - just a head's up - Bob
mykids is offline   Reply With Quote
Old 04-07-2016, 08:30 AM   #4
Rsmith38
Liked 28 Times in 15 Posts
Years back we started having tire troubles on out 26' tandem trailer.
Turned out that the Goodyear Marathon trailer tires are made in load range C and D. Only difference is the C or D about 1/16" high on the sidewall. Even dealers didn't know the difference until we bought a replacement from a FL dealer. We were unknowingly replacing Load range D original tires with lighter C tires - Doesn't work well on 10K trailer!
Check the load range on Marathons!
Rsmith38 is offline   Reply With Quote
Old 04-07-2016, 09:46 AM   #5
Mile High
Smile Re: motor home safety
The proper load range and air pressure are very important. My motorhome came with Michelins and will always have Michelins. Family Motor Coach Association has a discount program for Michelin tire.
https://www.fmca.com/benefits/michelin-advantage.html
Most trailer tires aren't rated for speeds over 65MPH. Slow down and enjoy the ride. I see many RVer's blow past me when I'm doing 65. I know we want to get there just take it easy. 65 MPH is enough.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 04-07-2016, 07:31 PM   #6
Ed Wright
Ed Wright's Avatar
The 10 ply LT, load range E Michelins on my trailer are rated at 110 MPH. 80 psi cold.
Sometimes if goes over 65 MPH.
Ed Wright 4156 SS/JA
