Out here in Tx I can get 24 empty,and if I am towing the open trailer I get 18-20.Mine gets the best mileage
at 62mph but it takes forever to get any were.Greg how do you like your new Olds,I nearly have mine up and running.
Alan Warman STK 4107 |
Liked 138 Times in 51 Posts
I have a Dodge 2004.5 Cummins Quad-Cab dually with an auto and 3.73 gears. It has a fiberglass topper that kicks up higher in the back and tows a 26' Pace which brings the total weight to over 19,000lbs. The trailer is still at least 1 1/2 feet taller than the back of the truck. I've gotten almost 13 mpg hand-calculated under ideal conditions, but usually get between 11 & 12. It looses a few more in the hills/mountains on the east coast. It's a time-consuming pain to fill fuel to the very top each time, but it's the most accurate way to check mileage. I usually cruise around 72 mph and, as noted, driving slower picks up mileage a bit. (The overhead computer has never been close, originally and even after a factory computer reflash for mileage, white smoke and computer mileage accuracy, especially after adding the box.)
It's all stock except for a Quadzilla 65hp/125tq tow box and an Amsoil EaA blue air filter. I believe they are more efficient than the oiled K&N and I've heard people debate whether or not the oil from it can actually affect sensors downstream. Drivetrain has all Amsoil: Series 3000 5w-30 diesel oil, Universal trans fluid, Severe Gear 75w-90 in the rear end and truck and trailer tires are kept between 75 & 80 lbs. The box picked up between .5 and 1 mpg. But I've always babied the truck and it has picked up mileage through 35,000 miles. It actually seemed to pick up more after a couple of occasions where I really got into the throttle! I "think" it's finally fully broke-in now after almost 50,000 miles. I also use Amsoil's diesel fuel modifer and cetane boost also. I thought about a wing/spoiler on the topper, but am concerned about it eventually cracking the fiberglass. Some people have said that a wing at the cab is too far forward to help much. The "bubble" on the trailer front seems like a good idea and I wish I would have ordered it when I speced out the trailer. I am considering an aftermarket, better flowing muffler and I've read that aftermarket fuel pumps help mileage also. Better flowing air boxes & tubes are suppose to help to. They are expensive and some people have swiss-cheesed their OEM air box instead. The older trucks should get better mileage because the newer ones like mine have an extra pre-combustion cycle. I forgot exactly what it's called, but it uses a little more fuel. A manual trans should also get a little better mileage over an auto. Then there has been talk of "seasonal" fuel that affects mileage and there is always wind or unnoticable grades in the road. I did get a 60 gal. auxilary tank and plan my stops in states with cheaper fuel prices. Flying J has good prices, online locations & prices and an RV card that saves 1 cent per gallon. Amsoil source & info: http://www.thelubepage.com/
LOCOMOTION Racing |
We have a 2004 Ram 4 door 2500 4x4 with the Cummins. Average mileage increased drastically when we purchased a 28ft Goldrush. We are seeing around 16-17 mpg towing to MapleGrove from NH.
Dusty Lowell 1773 F/SA |
