I have seen a few comments on playing the ladder and would like to get more knowledge about it. Once you have made your 1st time trial is that not the base for your ladder position, which you can only change with a quicker ET on the next run(s). Please help me understand how you play with the ladder.
old 1608 stock racer |
Liked 535 Times in 86 Posts
Its pretty easy actually. You set your car up to run slower than its capable of for that time run, or, you hit the brakes or lift at some point prior to the finish line.
#3 | |
Liked 22 Times in 14 Posts
Thanks Rick Thomason GTOMayhem |
Liked 7,944 Times in 1,521 Posts
Usually, you are trying to avoid a Heads Up run......there are other reasons though....
Liked 1,937 Times in 582 Posts
Either trying to get or avoid a heads up run depending on if you are the faster or slower car in the class. Trying to position yourself for a bye run at some point in the competition. Trying to position your self to knock out another competitor in the points battle. There are other reasons some try to play the ladder. Its not real easy to do as there are usually a number of racers doing the same thing and it is difficult to land in the spot that you want. Personally I am not that good to be able to do that so I just run all out every run.
Mike Pearson 2485 SS |
Liked 223 Times in 73 Posts
What I don't understand is how you can have very much control over where you end up on the ladder given that others are also changing their qualifying positions in what seems to be to be unpredictable ways. I can see how I could choose to move up or not move up on the ladder, but unless I'm currently facing a heads up run against a faster car I'm not sure why I'd want to.
I guess this might clear up part of it: Do most racers stand pat with what they run in the first session most of the time, or is there normally a lot of reshuffling. If there's usually lots of changes in the ladder after Q1 it seems like the effect of me going faster would be extremely hard to predict. |
Liked 327 Times in 121 Posts
It seems like Russian Roulette to me with multiple people doing it.
Liked 520 Times in 132 Posts
Stephen Bell has the ladder figured out here in D4. He just qualifies No 1 all the time and a gets a bye first rd...........lol
I used to do that some, but I quit worrying about that, as I can't run as far under as Stephen. LOL
Ed Wright 4156 SS/JA |
It's not always about trying to line up a heads up run. Sometimes you might be trying to get yourself on one side or the other for instance a line yourself up with a late round bye run or simply trying to stay away from a buddy or teammates. It can be difficult at times but the majority of racers are flat out on that first round so then you just need to figure out where a select few are trying to get and line yourself up appropriately. It can backfire.....
