Liked 113 Times in 9 Posts
Check the accelerator pump gasket, they dry out from sitting especially after using VP fuels. Chased that for a while once.
Joe DeMarzo 1317 STK |
Liked 133 Times in 76 Posts
Described hesitation is usually too much or too little fuel. Too much and you'd get a black puff when it finally picked up. Too little and it's just a dead spot. I'd bet too little. I'd start by dissembling carb and cleaning thoroughly.
What carb does it have? |
Liked 2,485 Times in 697 Posts
X2.............Sound like Carb.
Liked 68 Times in 26 Posts
how much timing are you using? where is your total set at ?what rpm? just curious
Liked 880 Times in 311 Posts
Change the coil wire!
Adger Smith (Former SS) |
Liked 169 Times in 53 Posts
accelerator pump. they shrink after sitting up for a while.
Bill Bogues 4696 STK |
Liked 254 Times in 78 Posts
x2
Mike Moller NHRA 203 Q-R-T/SA |
Liked 10,712 Times in 2,230 Posts
Verify TDC and "0" on the timing mark.
Liked 2 Times in 2 Posts
??? explain?
Glen Myers 126 GT/HA used to Now retired |
What one wire in the ignition system causes the most resistance when it wears out or becomes ineffective at passing electrical current? It is the one wire that passes all 8 electrical impulses of the engine firing cycle. That one wire is used 8 times more than the normal spark plug wire. When that wire breaks down it is very similar to having a coil that goes bad. The spark energy is used up jumping inside the wire, just like a large gap resistor plug. If you ever find a bad one split it open and you can usually pour out the carbon/graphite that has turned to a powder or burned up. Test the resistance and you will see the bad coil wire is way up in resistance per foot than one of the other plug wires.
Coil wires should be replaced frequently. He did mention that it came back alive after a higher RPM. If it had low spark energy getting to the plugs at low RPM the coil wire can cause that. Oh, Low spark energy will make you think it is carb related because it shows up as rich at the plugs.
Adger Smith (Former SS) Last edited by Adger Smith; 05-03-2016 at 12:13 PM. Reason: SP & Add |
