Old 06-23-2016, 12:20 AM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Need rules for car build
Trying to get my car set up so it will pass inspections. Are there other places, specific to my car, to look besides the generic standard NHRA rule book? Not the engine but the car itself.
Old 06-23-2016, 02:52 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Need rules for car build
The car, as in Nova or Mustang, is basically irrelevant to inspection for tech. You need to know the class you want to run (Stock, Super Stock, ect.) and then go through the rules for that class line by line and compare it to your build. Note that some cars need to be in the NHRA Stock Car Classification Guide to be eligible to race. Acceptable body styles are generally listed in the first paragraph of each class section of the rule book.
Dale
Dale Shearon
68 Mustang 6394
Old 06-23-2016, 03:49 PM   #3
Coleydog
Thanks for input but I'm way past the points you brought up, maybe I'm asking the wrong questions.
Old 06-23-2016, 05:42 PM   #4
FireSale
FireSale's Avatar
Tell us more about what you have and then we can provide better input. Helpful folks around here.
Dale
Dale Shearon
68 Mustang 6394
Old 06-24-2016, 12:09 AM   #5
Coleydog
1969 Barracuda to run stock, 340 for now but will try 383 or 440 down the road. Seems a lot of the rules have changed in the last decade or so when I started this project. The last rule book I have is 2004 and the wording left a lot of room for interpretation. The best solution is talking to someone with the same type car (if they'll talk to me). Not trying to get secrets but what is acceptable to change or alter (from 2004) on suspension, rear end, wheel wells, roll bars-cage, seats.. Quite a lot of hoops to jump through just to get the last rule book, seeing if there's another way around that.
Old 06-24-2016, 07:54 AM   #6
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
The answers to all of your questions can be found in the rule book under the stock eliminator section. If you can't find a current rule book close to you, call Summit or Jegs and order one.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 06-24-2016, 09:52 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
You have a PM
Old 06-24-2016, 12:31 PM   #8
Rod Greene
Liked 242 Times in 81 Posts
I don't know where you live but get out to the race track and talk to the guys running a barracuda. One of the fastest in the country is a Norwalk right now. Another one runs out of Las Vegas. Both the guys that run these cars are very friendly and can set you on the right path.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 06-24-2016, 03:15 PM   #9
X2!
I assume , if you are building a class car, you are somewhat near where they run them.
Old 06-24-2016, 03:50 PM   #10
Coleydog
I live in VA and yes the races are on my agenda, love asking questions from any racer. That's how I got this bug.
