Old 07-10-2016, 10:08 PM   #6
Coleydog
Liked 53 Times in 38 Posts
Default Re: Tube bars out to front frame on a mopar?
On Mopars ,AMC's and Fords It is somewhat easier to do it with two separate tubes to the shock tower ,although I have not had any issues with doing it the way you are describing. .....I've done a few AMC'S that way.
The fragility of A body Mopar's in particular is one reason the change was made to allow the front bars , although more for the protection of the driver .
I've had to straighten a few frames on cars that were bent from wheelstands before doing a new cage and front bars
Exactly why I'm doing this, designed to be driven on a flat road, no wheel stands and twisting, thin metal attached whith a few spot welds. Thanks
