#21 |
Liked 21 Times in 7 Posts
We experienced a marginal performance improvement of .01 to 02 with a 2-step on a low hp Fox Body stocker. Would have to make a few more runs to have a better idea with reaction time, but certainly made staging easier/consistent.
To Bobby's point, we did not adjust fuel enrichment to accommodate the change so not sure if it's a true apples-to-apples comparison.
Greg Viscome 193 GT/QA |
#22 |
Liked 498 Times in 119 Posts
my car hates it (as do i) kills me about .05 at least - more in bad air ....
and i cannot stand that sound ... so im stuck in the 60s footbraking it captain
Jack McCarthy 3609 STK "the Captain" |
#23 | |
Liked 20 Times in 12 Posts
#24 |
Liked 101 Times in 27 Posts
Maybe someone will see this and reply but has anyone experimented with low rpm 2 step ......will the motor respond ok on the 2 step at 2000 ????
NHRA AND IHRA STOCK ELIMINATOR 2772 |
#25 |
Liked 28 Times in 15 Posts
Don't know about 2000 but my R/SA Jeep 4.0 leaves fine at 2550 - down from 3000 because the brakes won't keep it from pushing thru the lights!
4.0 is FI so can't say about a carb reacting. |
#26 |
I'm finding out little by little with experimentation, and it gets back a little to what some of you hinted around to, the quadrajet does not like "rich" fuel mixture when leaving on the mat with the 2 step activated by the brake. It will sit on the starting line and hold the RPMS but when you let go the "rich" will usually make it leave terribly, even though it will run great with the same carb setup when running with the footbrake only.
MAKING THE 2 STEP WORK WITH THE QJET IS A CHALLENGE in order to get it to perform at its best especially on a stocker that doesn't have a transbrake and has to leave at much lower RPMS......by what I am seeing testing the 2 step requires leaner setup to run at least reasonably well. Does anyone else have similar findings ????
#27 |
Liked 110 Times in 29 Posts
Plug the accelerator well tubes
#28 |
Guest
Posts: n/a
I used to leave at 2200 with my 455 Lemans. I did what Danny said. blocked off the accelerator tubes and it left great. Always to the floor.
#29 |
I`ve been using a 2 Step anywhere between 2000 and 3100 rpm and the 60` times seem to be about the same. All of this with a V6 "Stocker". I`ve also gone back and forth with foot braking as well and prefer the 2 Step for consistency. Low horse, small carbed cars seem to be more consistent leaving at WOT. I also 2 Step my Super Pro car (big block Chevy with a 950 Holley, dual line lock set up) with the 2 Step around 1900 rpm and it leaves just fine.That's my experiences at least.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
#30 |
Liked 14 Times in 8 Posts
