I'm in Ontario Canada and hot hear also which is prob playing a part ! Thanks everyone for the help!
Liked 10 Times in 8 Posts
What Motor do you have?
330 hp Vortec head in my car. Powerglide 2.10 low gear, 5.38 rear and a 94 inch circumference rear tire and you should make the 1/4 mile finish line.
F Federico NHRA J/SA |
Yes 330 hp car, i will check tire size i cant remember off hand,i'm not looking to brake records but think car should run 6.85 on a good day ? How fast are these cars going with 385 hp motors ? I am new to this crate motor stuff thanks
Yes, .85 is respectable in the 1/8. But , its all relative, depending on class. 3rd Gens with a 330hp generally run F G or H. In H 6.85 is fast, in F, not as much. How much does the car weigh?
Sorry for the delay i felt i should scale car before replying,so 30 inch tall tire and car is 3288 lbs with me in it !!
Liked 70 Times in 29 Posts
Why are you trying to run a power glide with a trans brake? Are you running it in stock?
Car would be much better with a metric 200.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 42 Times in 17 Posts
Im curious as well as to why youre running a transbrake, and if so, why you would inform us. Only if you are just running brackets with it then that's fine. I run the exact same combo and ran previously a glide, but now I have a th350 and the 60' times are much better, putting my metric in this week though with a 2.74 low. Your car is very heavy for what it can be, im at 3077 with me in it running F and I don't have any weight anywhere except for the majority in the drivers seat!! My converter stalls at exactly 5k which took me about 4 different converters to finally get the right one in the car. With a 2.75 low gear, shifting at 6500, and 5.38's my shift light comes on about 100-150 feet before the 1/4 mile finish line.
If you are running it in stock, what class do you plan on running? The 385hp guys are low 6's on average from what I've seen. |
