Old 10-11-2016, 12:13 PM   #1
Jim Kaekel
Liked 531 Times in 108 Posts
Default Re: 69 Camaro Weight
I think a lot of the aftermarket pieces are lighter, bumpers, fenders, etc. Unfortunately, I think the how much weight you want to lose is equivalent to "how much money do you want to spend".
Jim Kaekel 3836 STK
Old 10-11-2016, 12:35 PM   #2
jimmyparker
Liked 309 Times in 88 Posts
You may not need to get all the way to 50-50, most cars that I have worked on do well with 52% or so on the front.
The '67 six cylinder sub frames were sought after at one time as they were supposedly 20lbs light than the V-8 frame, I never weighed them to verify. They are easily identified due to not having the large holes on the inside near the bumper brackets.
jimmyparker is offline   Reply With Quote
Old 10-11-2016, 01:04 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Aftermarket front sheet metal is substantially lighter than stock ,as it the radiator support . ...Add the lighter pump,battery and master cyl and you have a substantial savings in weight ,but not your wallet.
Aluminum seats can save as much as 70 pounds and offer more safety.
As Jimmy said 50/50 really isn't necessary , I regularly have to twist arms to put weight back on the front of Stock and S/S cars
Old 10-12-2016, 10:36 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
The narrow master cylinder weighs 6 lb. so the most you could save is 4 lb--if you can find an aluminum version of it (or are willing to use the aluminum/plastic type). The fatter master cylinder is available in aluminum from SS brakes, but it weighs about 4 lb and takes more fluid than the narrow style.
Use bolts just long enough, and if you are very industrious, I know of a 1970s racer who cut apart the front subframe, removed the overlap, and re-welded it together.
Old 10-12-2016, 12:35 PM   #5
Tom Goldman
I've taken apart more than one old Stocker with all the non suspension bolts replaced with aluminum ones .
It's all the little 1,2,5 pound items that add up .
I ground 15 pounds off the back side of my AMX front bumper and mounts. mounted it with tubular bolts from the Sprint car guys up the road.
Old 10-12-2016, 03:16 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
Racing seats can save quite a bit. Lithium battery will save at least 40 lbs on the nose of a stocker.
Mike Pearson 2485 SS
Old 10-14-2016, 01:30 AM   #7
Jim Hawkins
Liked 115 Times in 35 Posts
I have 2 67's and one has the large holes in the subframe and one does not. The early car does not have them and they are both original V8 cars. I was told this was done midway in the 67 production for bumper bracket access.
Jim Hawkins is offline   Reply With Quote
Old 10-14-2016, 05:28 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
The '67 subframe legend was started to cover up some chemically milled parts. If the aura of "unique" parts is attached to some identifying factor, people tend to not look at other possibilities. Hence, the '67 6 cylinder subframes, the 520 "T" heads, etc.
Old 10-14-2016, 06:23 PM   #9
J&S Racing
Liked 319 Times in 82 Posts
Is there anybody still chemical milling parts??
Old 10-14-2016, 06:35 PM   #10
James Perrone
Liked 1,821 Times in 425 Posts
Once you have changed out brakes battery and other bolt in components you need to search in every where in the car and remove any little thing . A pound here and there adds up not easy but I can get my nova to the Fsa minimum 200 lb driver. Every little bit counts.
james perrone 1290 STK
