Liked 68 Times in 22 Posts
What is minumun valve to piston clearance? i have .100 on intake and .60 on exhaust. I am a little nervous about exhaust side. Is it legal to cut the exhaust valve pocket on the piston just a little? nhra stocker
Liked 507 Times in 116 Posts
Is that checked with checker springs or the regular springs?
68 Chevy11 327 F/S |
#3 | |
Liked 184 Times in 113 Posts
265 55 Chevys sure wish they can notch their flat pistons to get some valve tolerance. D |
Having raced 265" '55 & '56 Chevies, we damn sure flycut our flat top pistons for valve-to-Piston clearance. Mine was down 4 times by NHRA, three national records & once was protested, passed every time.
Ed Wright 4156 SS/JA |
Liked 1,830 Times in 415 Posts
No, it is not legal to cut the valve reliefs on pistons in NHRA Stock Eliminator.
I would probably consider 0.060" piston to valve clearance on the exhaust to be the minimum safe clearance, if it was properly checked to begin with, and you have very good valvetrain control.
Alan Roehrich 212A G/S |
Liked 7,939 Times in 1,520 Posts
Ed, we are talking STOCK eliminator.....Alan is correct. I might add just watch yourself in the water....
#7 | |
I don't get the remark about water?
Liked 652 Times in 184 Posts
I think he is referring to don't let it get away from you on a burnout. People tend to over rev a car in the water box.
As for vtp like Alan said above .060 .065 exh would be as tight as I've ever ran and it was okay for me. The intake is more forgiving. if I were you I'd advance the cam and get yourself some more exh clearance and less int in my opinion if you are worried about it . Good luck with it.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#9 | |
Curious. Why more Clearance on the Intake vs Exhaust. ?
