Old 01-04-2017, 10:27 PM   #1
Jim Cimarolli
Liked 166 Times in 46 Posts
Question 1967 Dodge Dart Steering Column
Is the steering column on a 1967 Dodge Dart different if it is a non-power steering car from the factory vs. a factory power steering car?
Jim Cimarolli is offline   Reply With Quote
Old 01-04-2017, 10:56 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: 1967 Dodge Dart Steering Column
The manual column is a couple of inches longer . If you are changing from a power steering box to a manual box , there is an adapter available so you can use the power steering column .
Old 01-05-2017, 02:59 PM   #3
Jim Cimarolli
Thank you for the info. We are actually changing a non power car over to power steering for street use. I just wanted to be sure we had the correct box before we began the swap. Looks like I need to find a P/S column. If anyone has one please contact me. 903-885-7736 or PM me. Jim Cimarolli
Old 01-05-2017, 04:46 PM   #4
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Jim,
Go to Moparts.com I'm sure you'll find one there.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 01-05-2017, 11:14 PM   #5
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I have one out of my 68 Barracuda, same I think, it should work. Going to the Gators? Dyno
Old 01-06-2017, 08:26 PM   #6
Jim Cimarolli
Smile Re: 1967 Dodge Dart Steering Column
Thank you, no not going to the gators. I'm helping a buddy with this project. If we can't figure out something we might holler back at you.
Old 01-06-2017, 09:33 PM   #7
George Mirza
The column length can be changed by breaking the two plastic shear pins in then. Once they are broken you can make them the lenght you need. I'm guessing they were designed to collapse in a collision. They are two piece and one fits inside the other. After they are attached to the steering box and steering wheel the lenght can't change.
Only issue you may have is the splined rag joint on the steering box end, I believe the manual and power boxes use different diameter splines. I have used a steering box to column u-joint in place of this, several companies offer them.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 01-07-2017, 11:05 AM   #8
Jim Cimarolli
Thank you George!
