Old 02-19-2017, 05:51 PM   #21
James L Miller
Liked 25 Times in 16 Posts
Default Re: What Works and What Doesn't
Who makes a large assortment of compression springs for oil pumps?
https://www.mcmaster.com/#compression-springs/=16fdm1j
Measure the ones you have, then look for ones with different free length or spring rates.
Mopar 2 Ya!
Old 02-19-2017, 06:15 PM   #22
Breadburner
S100 for a polish for Chrome and Aluminum...
Breadburner is offline   Reply With Quote
Old 02-19-2017, 06:28 PM   #23
FED 387
Liked 333 Times in 180 Posts
Larry Hill check your PM
Old 02-19-2017, 09:10 PM   #24
Liked 10,763 Times in 2,237 Posts
Thanks FED 387
Old 02-19-2017, 09:30 PM   #25
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
What works:
Walmart carb. cleaner, Walmart break parts cleaner, less than $2.50 for a 14.5 Oz. can. Jeff Taylor Performance cylinder wall preparation, calling it a hone job just doesn't give the process full recognition.
Pro Trans, Joel's on Joy, and Arnett Transmission.
What works is a Allen Sherman built racing engine, a clutch built by the Hyatt's, and Mark Lelchook headers....
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-20-2017, 12:21 AM   #26
voltdr
Liked 100 Times in 51 Posts
Want to get the streaks off of your trailer, RV, or motorhome without the alot of elbow grease. "LA's Awesome" cleaner. I get it at Dollar Store. Others have it also. Only $1.00 a bottle. Spray on wipe off.
Dan
voltdr is offline   Reply With Quote
Old 02-20-2017, 12:11 PM   #27
Dollar Tree's version of CLR will clean rust and crud off of bolts and hardware. Let them soak for a day or two.
They don't have it all the time, so if you see some , grab about a half a dozen bottles.
If not , Zep's version is cheaper than CLR..Get it at the sticks and bricks store.
Old 02-22-2017, 10:03 PM   #28
S/ST J718
Looks like everyone has a favorite , been in the Harley world now for 27 years so I have tried a lot of great polishes . But the best I have found at is available at Walmart , its called Cape Cod Polishing clothes . American made and this will leave a protective coating resisting future tarnish . here's a link https://www.walmart.com/ip/Cape-Cod-...-Each/23500565
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
Old 02-23-2017, 10:52 PM   #29
Ed Carpenter
Dan
I've used this it really works.
Ed Carpenter
Old 02-24-2017, 10:46 AM   #30
Rsmith38
Liked 28 Times in 15 Posts
I have also used the Awesome orange from dollar Stores - works well.
They also have a refill bottle (clear plastic, yellow liquid) for $1 which makes 3 to 5 refills - for a couple of bucks you can do a trailer! Stuff also cleans under hood on used cars, Spray on - let sit, Hose off!
Rsmith38 is offline   Reply With Quote
