#11 | |
Liked 784 Times in 196 Posts
#12 |
[QUOTE=amxron;528792]dmir55,
Would you post the 57 Ford sheets for me? Thanks, Ron.Could narrow it down some. There six engines listed and 52 body combos. 26 with a stick and 26 with a FOM. I have to hand print them for you. |
#13 |
Liked 129 Times in 59 Posts
So what would happen if someone showed up at an NHRA Lucas Oil event with a vehicle that is listed in the Stock Car Guide (for example, a 1955 Cadillac) but there are no tech spec's published/available? IIRC the rulebook states that the vehicle must be listed in the Guide, but there is no mention of technical information.
As loose as the rules have been/are interpreted, and if the information was/is still available in some format, how difficult would it be to "recreate" those lists and fill-in the missing documentation. The complaint that it would be too costly doesn't seem to be a reason not to do this. How hard would it be to build a Microsoft Word document? I know some folks have complained that there are too many "classes" in Stock and Super/Stock Eliminator, but has anyone had a problem with too many valid "combinations" in the Guide?
Lew Silverman #2070 "The Wagon Master" N/SA |
#14 |
Technically, Lew, they have to let the car race. Their problem comes if they have to verify that it is legal. Right now, all they have is bore, stroke and displacement.
#15 |
Thanks, Dwight!
More projects for another lifetime!
#16 |
Liked 160 Times in 51 Posts
How about running a 1957 Ford 2 dr post in SS GT class with a 1974 460! There we go!
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
#17 |
dmir55,
The Retractable hdt (Skyliner) w/ the 300, 270, and 245 hp with auto would be great. Thanks, Ron. Last edited by amxron; 03-09-2017 at 03:13 AM. Reason: add |
#18 |
Liked 43 Times in 10 Posts
#19 |
[QUOTE=amxron;529057]dmir55,
The Retractable hdt (Skyliner) w/ the 300, 270, and 245 hp with auto would be great. Thanks, Ron. 57 Hardtop Skyliner (Rtract) 245 hp 15.98, w/FOM 16.32, 270 hp 14.50, w/FOM 14.81 and 300hp 13.05, w/FOM 13.33. This is why I asked for a certain body style. It's like this for every body style and is two more engines. Hope this helps. |
#20 |
[QUOTE=Lew Silverman;529047]Thanks, Dwight!
More projects for another lifetime! As long as I have the book out. Hdtp Cpe 5 (DeVille) 250 hp 17.33 w/Hyd 17.69 and 270hp 16.05 w/Hyd 16.38. Those old trannys must weigh as much as the engines. |
