View Poll Results: Fuel injection? Do you run in open loop or closed loop | |||
Open Loop |
80 | 65.04% |
Closed Loop |
43 | 34.96% |
Voters: 123. You may not vote on this poll |
Thread Tools | Display Modes |
Liked 70 Times in 31 Posts
Thanks. I plan to run Sunoco Turbo Blue. That's what I've been running in the Camaro LT1. I'm still using C-11 in the LS1 but plan on switching to Turbo Blue at the next race.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
Liked 62 Times in 29 Posts
How does the LT1 compare to the LS1? The LS engines have a terrific head, but have they been killed with HP? Do they hold-up without oil pressure issues? I have seen several munch cam bearings for no reason..... And these were just 500-600 hp street engines spinning less than 7000.
Sorry to say, but I don't know a lot about either engine.
Darrel, you have not had problems with Sunoco passing fuel check? Maybe it's better now. I tried that stuff when it first became "the official fuel of NHRA", to prevent hauling fuel in my trailer. Saftey issue. Lost two qualifying runs, at two different races. Bought the fuel from Sunoco at that track. Maybe it's better now.
C11, in my LT1 SS car, runs the same times between 12.8-1 and 13.0-1. Maybe half a MPH faster at 13.2-1 above 7500. I use Speed Density mode, Open Loop.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 04-13-2017 at 09:50 AM. |
#5 | |
I thought you were using closed loop now?
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com Last edited by Darrel Goheen; 04-13-2017 at 11:45 AM. |
Played with closed loop, saw no need. Once I ran in enough different conditions to get runs in enough different Baro conditions, to get each cell corrected, logs always show correct air/fuel anyway. If it were in Closed Loop, it would not be making any corrections anyway.
The manifold air temp sensor helps consistency a lot. All weekend at Houston recently, it varied exactly one hundredth. First three passes over two days at No Problem Raceway last week, it only varied four thousandths, then it broke a lifter. Did not repeat that close without the manifold air temp.
Ed Wright 4156 SS/JA |
#7 | |
