Liked 99 Times in 49 Posts
The best combo would be the 270 350, if you are in this for the long haul . Buy the best block you can,you can run a cast piston and stock rods red line cam regular lifter, race rings , corvette pan std oil pump buy a set of older stocker heads,there are several guys that can get a set done. But really be hard to do it for under 5500.00 not counting trans and convertor. Nice look chevelle good luck. Then up grade as you go.
