Old 06-13-2017, 04:13 PM   #12
Jeff Niceswanger
Liked 1,071 Times in 378 Posts
Default Re: Stk/super stock combo June 17 5000 to win
Originally Posted by Jon Sarrett View Post
Wow that's a pretty heavy handed opinion you've got there and I can say you're not even in the same park, hell, you're not even in the same sport! I live 13 miles from 42 and 27 away from Norwalk. I will be running the event at 42 this weekend and also the nationals the following week. I cannot take the time off work to drive to Toronto nor can I justify the expenditure when I can race for $5k for a hundred bucks less than 30 minutes away from me. With that said, which one will you be attending this weekend? When was the last time you've had a heads up race? Will I see you in stock or super stock next week at Norwalk? I see 3 N's in your upcoming response...neither, none, no.
If Joe keeps the classes separated as he usually does ( until the end) and there is a strong car count, there will be strong chances of some heads up runs .. At the Dave Layer Memorial that Rodger Keeling put on down to the now defunked Kanawa Valley a couple years ago ...The Final was a Heads-Up race . De-De Layer was adamant that it was going to be Heads -Up ... And it was .. No scales, No Fuel check ... The finalist were pitted right across from one another, so it was a little easier ... But when there a will ...there's a way
Jeff Niceswanger 3740 SS
