Old 06-14-2017, 12:40 PM   #37
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: All 305 Engines Horsepower
Sealing a "scoop" to the carb is not always beneficial, but how could directing fresh air to it not be?
That's correct. The inlet area of the scoop is more critical than the size of the scoop. If the inlet is too big, then you need to bleed off the excess of inlet air due to the fact it will induce drag on the car and unnecessary turbulence inside the scoop that will effect the performance of the engine.
Also, a hood scoop only becomes effective after specific speeds.
