Old 08-20-2017, 09:05 PM   #30
David Barton
Sponsor
Default Re: AA/SA Mark Madison, Seaside CA, '65 Belvedere 9.516
Originally Posted by Tuki View Post
Hoven can't fit in A with out taking the cross ram off he had on at Cecil..Barton knows the single 4 cause he ran it when bombed the index at Indy when the combo first came out that's why our car is 3730 in A..it will be interesting in A or AA but no AA car is going to out run Marks
Wrong. The P/W ratio is 7.57 making the car naturally fall into AA and you are allowed to drop down a class. When the combination hits 455 HP then it will be AA only.
When exactly did I "bomb" the combination at Indy? Show me the results. That has to be 10 years ago. I remember the combination getting slammed before it ever hit the track because others were complaining about it.
Which combination are you running? Iron or aluminum heads? Single 4 or crossram? Sounds like you're claiming the aluminum headed engine which carries extra weight. Put some iron heads on there and lose the weight. I guess it's easier to place the blame on me.
David Barton is offline   Reply With Quote
