Liked 239 Times in 114 Posts
If the manufacturer did not submit the specs for the car , then it is not eligible to run , under NHRA rules . You might be able to contact someone from FCA to submit the specs , but it will be hard to get those older cars listed . Good Luck !
Liked 248 Times in 89 Posts
Let me guess. You're trying to build a Ford newer than 2002 that isn't a Mustang?
Liked 7 Times in 5 Posts
nope 2005 dodge magnum with a 5.7 its long wheel base but for 1900 bucks for the car to start with thought it might have potential i'm guessing fords other than mustangs don't make the guide very often past 2002.
