#1 | |
Liked 1,349 Times in 412 Posts
Darn blankets get super dirty. Drag your straps throw the water box for a little extra cooling. |
Liked 3,204 Times in 977 Posts
Anybody with experience using the Tom Waters shield on a 904? Want to avoid a repeat of a bad experience trying to mount a TCI shield in an A body years ago, lots of notching/trimming required which of course rendered the classification spec useless.
https://racecarpartsdepot.com/shop?o...roducts&page=2
Several years ago at Mission, Dan Cyrs A/SA 69 Camaro had an automatic transmission explosion so severe that it sent scrapnel up through the dashboard and out the windshield. Pretty scary stuff. Thay worked late into the night patching up the damage and installing a new windshield, and did race the next day. I have also seen the aftermath of several Torqueflights and Turbo 400s that blew apart, easily as bad as a clutch explosion on a stick car, but normally further back, and closer to the driver, and often in an area where the tunnel has been modified.
#4 | |
Liked 239 Times in 94 Posts
![]() It was just as the car came out of the burnout box and sent parts everywhere. Quite a bunch of damage to the car and maybe just luck the parts went straight up and straight down rather than out the sides , Dan can still walk. |
Liked 10 Times in 6 Posts
What transmission was he using?
#6 | |
Liked 70 Times in 31 Posts
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
Liked 15 Times in 7 Posts
Jeff I will take it along with those 83/4 axle straps you had saved for me give me a call Bryan Dixon 605=999-9220 thanks
Liked 13 Times in 9 Posts
I have the full carbon fiber CSR shield on the Volare. The transmission tunnel is tight, and it barely fits, but it fits. We use the star head pattern bolts (fir head?) that use a 3/8" 12-point socket, a good swivel, a 3' extension, and as SS3011 said, the trick is to let the engine and trans down as far as it will go to give yourself enough clearance to have a prayer of getting to the bolts. I remove the trans mount, pop the distributor cap off and lower the engine and trans down as far as they will go -- the engine lays back very close to the firewall. With the right tools and a lot of practice (which I have gotten over the years, unfortunately), it's not as much of a completely god-awful job as it used to be.
And yes, it required taking a couple of ears off the trans to make the shield fit.
Liked 10,813 Times in 2,247 Posts
I think it is made of Kevlar.
They list it as an "aerospace composite". Whatever it is, it is TOUGH!
