#81 |
That's because you were searching for them LOLOLOLOLOL!
Todd Greene |
#82 |
Liked 53 Times in 38 Posts
Wow, with all those different Chevy heads it does look like crate engine time. I thought we had it bad with a Chrysler, 2 maybe 3 different ones. Is Ford like that? I know they got a ton of different engines.
#83 |
Liked 5 Times in 4 Posts
Has anyone contacted NHRA and have them explain how the SBC heads they approved are going to maintain the same runner volumes as the stock head they replace!
#84 |
Guest
Posts: n/a
It’s up to the racer/engine builder. Not NHRA how that is accomplished. No different that the way it is done now with OEM heads and replacement heads. The NHRA night allow the bigger head and volume the way it is. It’s happened for some of the heads approved now.
#85 |
Liked 393 Times in 153 Posts
So, first;
Do you think Edelbrock did their due diligence and got this head accepted, good for them, or Edelbrock somehow has an "in" and that's why so many of their heads are approved (conspiracy theory?) and this is all about padding the coffers of a company loyal to nhra? Second; I have numerous ford heads in my shop, but they are not the correct year/number/etc so basically they are garbage, even though they are unmolested stock heads. Would love to see the hundreds of ford heads replaced with one as well. Alternatively, I'd like to see all the ford heads that are identical but different years all accepted as the same. Same valve size/chamber size/runners/everything but they have different numbers due to the casting year. Yes some have big/small plugs (no performance advantage) and different rocker arm bolt down methods, but seriously, I'd rather just say if its a stock ford head, then its good. Obviously 4v and 2v Cleveland casting are different and would need different numbers, but all 2v heads and all 4v heads could have the same number. Third; Just questions, don't get your panties in a twist! Lol! Of all manufacturers to get a replacement stock head..chev? REALLY??? Change ford or dodge and you will affect a certain number of racers, but sbc??? AMC, I could see that, or Pontiac...Buick maybe...but CHEV??? How about a caddilac head, I could see that.... |
#86 |
Liked 99 Times in 49 Posts
#87 |
Liked 16 Times in 10 Posts
Nhra making America great again!
#88 |
Banned
Liked 235 Times in 110 Posts
#89 |
Liked 184 Times in 113 Posts
Wasn’t there a class called "Modified Stock" ?
Seems like the Stockers today fit that Class? and Going quicker! D Last edited by Dan Fahey; 04-07-2018 at 08:17 AM. |
#90 | |
Liked 89 Times in 19 Posts
c
Chuck Norton |
