Old 01-28-2018, 03:22 PM   #11
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: torque wrench recommendation
I use the good ol' Craftsman beam torque wrench. It's accurate and easy to use. Even Chrysler suggests the use of a beam type torque wrench.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 01-28-2018, 04:44 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Years ago I used an S-K deflecting beam 1/2" torque with the pivot pin on the handle to keep the force in the exact position to get correct readings and today I still use a 50 year old 3/8" drive S-K beam torque wrench with a ball handle for setting up bearing pre-loads......
Bob Mulry 7516 STK
A & M Motorsports
Old 01-28-2018, 06:50 PM   #13
SSGT Mustang
Liked 204 Times in 54 Posts
Precision Instruments. I have several including the dial type which I use mostly.
http://torqwrench.com/
SSGT Mustang is offline   Reply With Quote
Old 01-28-2018, 07:30 PM   #14
ron b
Liked 4 Times in 4 Posts
[QUOTE=SSGT Mustang;554658]Precision Instruments. I have several including the dial type which I use mostly.
http://torqwrench.com/[/QUOTEwere nice looking product. I am going to call them tomorrow. thanks
ron b is online now   Reply With Quote
Old 01-28-2018, 10:05 PM   #15
SSDiv6
CDI is one of the major torque wrench manufacturers and they make the torque wrenches for Snap-On.
http://www.cditorque.com/
Still, my preference for accuracy is my old Sears Craftsman Electronic Rotary Torque Meter that was discontinued many years ago.
Had it checked many times for accuracy and right on spot.
It measures ft/lbs, metric and torque angle.
Old 01-29-2018, 05:44 PM   #16
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Originally Posted by ron b View Post
where are you getting your wrenches calibrated and what is a round about cost?
Ron, SnapOn has a calibration service . Last I remember it was around $75 .
Old 01-29-2018, 07:00 PM   #17
SSGT Mustang
[QUOTE=ron b;554664]
I typically buy them through tool warehouse. They have good prices and offer incentives for repeat customers.
https://www.thetoolwarehouse.net/Sea...on+instruments
Old 01-30-2018, 06:50 PM   #18
tim worner
Liked 126 Times in 20 Posts
Husky 27" 39104 available from Home Depot lifetime replacement. Haven't lost a cly head or ring gear yet.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 01-30-2018, 07:02 PM   #19
CMcAllister
Liked 923 Times in 262 Posts
I have a variety of both the click style and "Torq-o-meter" dial type, all Snap On. I've tried to have enough of various click style wrenches so I only ever need to use the middle 50% of one to get a job done. They don't work well at the extremes of the range.
Old 01-30-2018, 07:15 PM   #20
Race Clean
Liked 129 Times in 53 Posts
A torque wrench only measures friction.If you do not follow the specs for the bolts you are using(lube,washers,etc.) you will be far off even with the most accurate wrench.
With that said I use SnapOn with dial for best result and "feel".
Race Clean is offline   Reply With Quote
