Liked 431 Times in 224 Posts
That's pretty high, but not crazy. Lowering the pressure will slow your reactions, but there isn't a ton there if you are keeping the pressure within reason.
I run 32-35 psi in my 3600# Super Street car. I typically bracket race it, and use starting line RPM to adjust reaction rather than tire pressure. I can't tell if your question is: 1. I run 40 psi in my tires and I think it might be too high, but what will happen to my reaction times if I lower the pressure? 2. I need to slow my reaction times. Will lowering the pressure in my front tires accomplish this? If #1, I'd probably drop 5 psi and you likely won't notice the difference. If #2, I'd still drop 5 psi, but you'll get more change in R/T through RPM adjustment or rear tire pressure.
S/ST 51 S/C 53 |
