#51 |
Liked 5,119 Times in 1,950 Posts
Yes, that's where we hooked up our pressure gauge and test valve. It helps if you have a jumper switch to the fuel pump relay, for a serious effort.
#52 | |
Liked 302 Times in 73 Posts
and yes to quote my original reply, I'm very interested in this combo, just don't want it to be destroyed before I can afford to try it.. I would love to get a group of us together to petition NHRA to change the V8 only rule for SS/GT. I can count the number of cars on one one (maybe it would take 2) hand that are being produced with a V8 these days. Would be nice if we could run those engines, I have talked to Don Kennedy about getting the rule changed as I know he was heavily involved in writing the SS/GT rulebook. He is on board and has attempted to make some calls, no luck getting who he wants on the phone yet but this was a very recent idea.. If there are more people out there interested, keep pushing them for change. It will take a group of us showing interest over just one guy. Just some info on the engine at hand. There are some very big issues with this engine when you make a lot of power over stock. If someone is really wanting to run this combo I suggest doing your research before turning it up much. Block and Intercooler are the first 2 that come to mind, but I'm not an expert yet and have just dabbled in my research. Brad |
#53 |
Liked 805 Times in 245 Posts
I am familiar with Ecoboost / Duratec engines, I am not aware of any block strength issues. There are a couple of minor weak areas that need attention but very easy and inexpensive to fix. What do you know that I don't?
Regarding the damper, I guess one persons pulley is another man's damper. I have one of these in my shop and it looks like a pulley to me. That being said, the Ford 2.3 single OHC motor doesn't technically have a damper either. Mine does because I retrofitted an SBC unit to it but not the way it comes from the factory. Jim Caughlin SS 6019 |
#54 | |
Liked 135 Times in 74 Posts
#55 | |
#56 | |
Liked 7 Times in 5 Posts
Roland |
#57 | |
Liked 117 Times in 50 Posts
Airaid Intake Turbosmart Wastegate 3" Open Down Pipe Wagner Tuning EVO II Intercooler Methanol Injection Kit UPR Products Dual Catch Cans BMR Suspension upgrades Viking Rear Shocks Weld Racing wheels wrapped in 17" MT ET STREET R and Front Runners VP Racing Fuels MS 109 |
#58 |
I'm not planning on setting any records or racing at Indy. I'd just like to comfortably run under the index. What are the odds that I'd be subjected to a tear-down?
#59 |
here is the description for the head from the Ford Performance website.
Fits 2015-2018 Mustang EcoBoost engines This is the production IEP (integrated exhaust port) cylinder head Includes water jacket plugs and valve seals Does not include valves, valve springs, retainers, valve locks or tappets. Same cylinder head used in Brad Gusler's NMRA 1/4 mile record setting EcoBoost Mustang |
#60 | |
Most of those failures look preventable to me. That fuel pressure sensor will apparently cause the engine to lean out under boost. It can be monitored in real time, using an aftermarket hand-held "tuner". And Ford has an updated replacement part available. |
