Old 07-16-2018, 11:20 AM   #21
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: EFI control units
Originally Posted by btrc View Post
Do you ever have problems the idle after you transferred the changes to base? I have mine at learn only above 5000 rpm and anything below is open loop but I still have idle problems after I transfer the changes.
Your probably allowing it to smooth everything . It will indeed change everything on the map, including your idle areas if you allow it to do that. I don't smooth at that time.. After transferring to base, if you want to smooth all the changes (which is a good idea), go back into your map, highlight everywhere BUT your idle area, and maybe your WOT row, and hit smooth.
Also, if the learn map is coming up with changes in the idle area on its own somehow, just zero them before transferring. If its doing that, something in your setup is not right. The learn is in 8 cell blocks or something like that, so it will "bleed" learning down into areas that are not selected.
Jeff Niceswanger 3740 SS
