Old 06-14-2018, 12:58 PM   #11
Jim D'Amore
Sponsor
Jim D'Amore's Avatar
Liked 66 Times in 17 Posts
Default Re: Poking the Bear Ford Performance Products
Originally Posted by kdanner View Post
I have examined the part in question before. It was 2 pieces of 5" aluminum tubing welded together with one end formed to the shape of the throttle body, the exterior weld ground smooth, beads rolled on the ends to help keep it in place, black crinkle powder coated, no identifying numbers/marks on it anywhere. Seems to be easily enough duplicated.
Most of the fastest CJs run the OEM PCM? Maybe I missed something somewhere but I'm pretty sure that is not what I am seeing on any of the Holbrook engines. How many cars are we talking about using the OEM PCM? I can't imagine running OEM, but then again I wouldn't use something like BS3 either when something as capable as the MoTeC ECUs and dashloggers are on the approved list. For me it was a no brainer to buy MoTeC. There's certainly no RPM limit problem there either.
We currently have 16 Cobra Jets that we are tuning and support tuning for using the factory PCM and some of them are the fastest of their kind. The only limitation we've had is RPM and through our own research have made great strides but have never had support from the current Ford Performance drag race manager in doing so.
Jim D'Amore is offline   Reply With Quote
Old 06-14-2018, 01:11 PM   #12
Jason Fuller
Jason Fuller's Avatar
How many RPM's are you running at top end? 10,500 or More?
Jason Fuller is offline   Reply With Quote
Old 06-14-2018, 01:37 PM   #13
Jim D'Amore
Sponsor
With the factory PCM we can run up to the following max RPM...
2008-2012 5.4L CJ cars are 7,800 RPM max
2013-2014 5.0L CJ cars are 8,200 RPM max
2016 5.0L CJ is 8,500 RPM max
Old 06-14-2018, 01:51 PM   #14
Jason Fuller
It's truly amazing what you are doing performance wise within these rpm's.
That being said, Time to call Robin Lawrence at Holley.
Old 06-14-2018, 02:46 PM   #15
Jim D'Amore
Sponsor
Originally Posted by 600ci View Post
Hmmmmmmmmmmmmmmmmm the sword is mightier than the pen
we'll see
Trust me I'm well aware...after my company's loyalty to Ford for 36 years and the millions we've spent with them between Ford parts & service as well as Ford Performance. He makes it very clear he will do anything to including calling me a cheater to NHRA, even though NHRA tech'd the car legal for its class.
In his very last phone conversation with me he told me that I should be quiet and to not poke the bear.
Old 06-14-2018, 03:38 PM   #16
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
My prior comments were about the tube between the throttle body and MAF rather than the part you've pictured as I'm sure you know, just clearing that up for anyone else reading. Wasn't clear what you meant by air kit.
Fastest of their kind rather than just saying fastest was a good clarification you've made. Carson's car certainly is real fast at 9.33.
Just a suggestion Jim, there is something to be said for poking the bear. I've seen posts on here from you like "Charlie Bob eat me" also. That doesn't play well here. I've learned at times it works out better for me to type out my diatribe about something, then delete it without ever sending. I wouldn't think this thread is going to be helpful for you.
K Danner STK 468
kdanner is offline   Reply With Quote
Old 06-14-2018, 05:28 PM   #17
Jim D'Amore
Sponsor
I understand, I appreciate that and thank you.
Old 06-16-2018, 08:46 PM   #18
goinbroke2
Liked 393 Times in 153 Posts
As a die hard ford guy I find this extremely frustrating!!!
One thing to fight the competition, but to fight our own....arrg!
Old 06-16-2018, 09:29 PM   #19
GUMP
Liked 2,354 Times in 554 Posts
At this point we have only heard one side of the story.......
Old 06-17-2018, 12:43 AM   #20
davidhuff
Liked 120 Times in 42 Posts
We are waiting because this is a open forum for his side of the story.
