Old 08-07-2018, 10:20 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Oil pressure question
Thanks Ed, is that Valvoline part number 822388? I know they have a Not Street Legal oil and a synthetic racing too, right?
Ron Gusack is offline   Reply With Quote
Old 08-08-2018, 07:37 AM   #2
Alan Nyhus
Liked 800 Times in 237 Posts
Ron, what are you using for an oil filter? Is the bypass blocked off? -Al
"That'll never work....."
Old 08-08-2018, 07:57 AM   #3
Ed Wright
Ed Wright's Avatar
Only part number I see on the bottle is VV205. Says high Zink & Not Street Legal on the bottle.
I used to pay a lot more for Royal Purple, I have seen zero difference in bearing, pushrods ends or ring/cylinder wall wear, or conditions.
NAPA Gold 1061 oil filter. Has no bypass. Used AC & Fram filters before that, they did have a bypass. Found more crap in my bearings then. Stays in the filters now.
Ed Wright 4156 SS/JA
Old 08-08-2018, 09:30 AM   #4
Ron Gusack
Ron Gusack's Avatar
Yes, VV205 is the same as 822388. I use the Wix 51061 which is the same as the NAPA Gold 1061. Is the spring thing in the bottom of that filter some type of a bypass? I know they say there's no bypass and I've never taken the time to actually try to figure it out.
Old 08-08-2018, 10:44 AM   #5
Ed Wright
Ed Wright's Avatar
Yes, WIX makes NAPA filters. I guess if the filter clogged up, the Spring would allow the element to move back to allow it to bypass. I also have an Allen plug in the filter mount bypass hole.
Old 08-08-2018, 11:48 AM   #6
Ron Gusack
Ron Gusack's Avatar
I found some vv205 for 5.80 per quart. That's cheap enough to scare me away. I gotta call Valvoline and learn how to tell if it's a Chinese knock off before I put it in the engine. Maybe I could send in a sample to see if the numbers match Valvoline's.
Old 08-08-2018, 01:10 PM   #7
Ed Wright
Ed Wright's Avatar
Let us know what you find out. Has been fine in mine.
