#31 | |
Liked 7 Times in 6 Posts
#32 |
Yes, WIX makes NAPA filters. I guess if the filter clogged up, the Spring would allow the element to move back to allow it to bypass. I also have an Allen plug in the filter mount bypass hole.
Ed Wright 4156 SS/JA |
#33 |
I found some vv205 for 5.80 per quart. That's cheap enough to scare me away. I gotta call Valvoline and learn how to tell if it's a Chinese knock off before I put it in the engine. Maybe I could send in a sample to see if the numbers match Valvoline's.
#34 |
Let us know what you find out. Has been fine in mine.
#35 |
Liked 336 Times in 183 Posts
Valvoline VR-1 racing oil comes in multiple viscosities from 30W to 60W straight and 10W-30 and 20-50W multi grade--- A good going price is between about $7-9 per quart--- you have to shop around Most of the big box auto parts stock it or can get it quickly---Google VR-1 on Valvoline website you can read all about it--FED 387
#36 | |
https://www.carid.com/valvoline/vr1-...mpn-vv205.html |
#37 | |
My cylinder walls, bearings, and Intake pushrods ends do as well as anything I have used. I will keep using it, thanks. With 1015 lbs open pressure and 1.8-1 rockers, not all oil I have used has done as well. Ron says it's cheap Chinese crap. :-) I use 10W30 @ 40 psi.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 08-08-2018 at 07:07 PM. |
#38 | |
Liked 239 Times in 114 Posts
#39 | |
What do you use?
#40 |
For the street I use Mobil 1 5-30 which is a Dexos equivalent . Lately for racing I have been using Joe Gibbs racing oil , and Wix racing filters . I have not had any oil related problems with either oils . The Mobil 1 oil works fine as a racing oil in my 454 Super Stock engine , but changed to the Joe Gibbs stuff just so my break-in oil was the same brand as my race oil .
