#1 | |
Liked 184 Times in 113 Posts
Until buying one of these $70000-80000 beasts. The Hot Rodder in me going to fix up what I have. My wagon has been beefed up to tow long distances with a trailer. It is safe and learning what really works. Had a recent accident Where a nut took out my side of the wagon in a two lane left turn. I was in the outside lane. Parts are becoming a problem as the wagon becomes more of a classic. Front doors are hard to find and rear wagon doors a lot tougher. Wagon will get fixed. But time to start searching. Plus my neck is still sore. Have been looking at enclosed trailers. This requires a whole new set of considerations. Especially dealing and understanding wind shear ! Here is what I have learned. Just bought Hughes Towing Converter. Love its features as it is Designed to operate cooler than a Stock one. There are other towing converters with a bit more stall. Moves the torque curve up a bit but adds heat. The Hughes Towing Converter Stall is slightly larger and tighter. Specs say it flows the trans fluid better to reduce heat. So will see how this combination works. The current towing converter and 3.08’s work great over mountains. It has a bit more stall than the stock converter. But the 3.73s and new Converter will reduce strain on the cooling systems. Interestingly gas mileage for towing will not be impacted. Unloaded fuel mileage will suffer but rarely for towing. Trucks are geared to get decent non loaded/towing fuel mileage. Because 90% of their use is Unloaded. Here more gear and tighter converter would work for distance Towing. The rear squats couple inches when loaded, using up the GVWR. Easily fixed adding airbags and electric pump. This also helps front end geometry reducing any white knuckle feeling. Also improves GVRW and CVWR. So for all the bluster here. Trucks still require specialized upgrades for long distance towing. Local and highway sprints are not an issue. So if a person tows with an unprepared truck and had a bad experience! Well...fix it! D Last edited by Dan Fahey; 09-09-2018 at 02:48 PM. |
