Old 10-22-2018, 08:13 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: BBC in Gen 4 Camaro
I’ve talked to Mike and he gave me some good tips. I’d like to know what intake and oil pan guys are using that meet the tight dimensional parameters.
John Nechiporchik is offline   Reply With Quote
Old 10-22-2018, 08:45 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
John, My 4th Gen Firebird was built by MPR, originally as a GT/AA, with a 454 BBC under the hood.
The K member has been modified for both oil pan (Moroso 21049) clearance and custom headers as has been the cowl. Without doing the same to yours, I don't see it happening. Lots more done you don't see.
That said, my engine is not super stock legal and the edelbrock Vic Jr on it has had it's carb pad cut down for hood clearance though I do have a 1" restrictor plate on it.
Old 10-22-2018, 04:05 PM   #3
John Nechiporchik
Ed, Thanks for the information and the photos.
My chassis is modified in a similar fashion as yours with modified crossmember and cowl area. It appears that my rack may be a little further rearward which may restrict lowering the engine in the chassis. Might require modification.
Again, Thanks for your response and helpful info.
The mock up process will continue to see if I can sort this out.
John
