#1 | |
Liked 10 Times in 6 Posts
Liked 24 Times in 8 Posts
Liberty Gear 5-speed with the Long shifter.
They will get you the trans ratios you need for your combo. |
Liked 225 Times in 136 Posts
Much better service from G-Force QUOTE=Don Anderson;576108]Liberty Gear 5-speed with the Long shifter. They will get you the trans ratios you need for your combo.[/QUOTE] |
Just looked at the G-gorce ratio chart, impressive.
Todd Greene |
Liked 299 Times in 48 Posts
Hey Don - Which Liberty 5-speed trans are you running? Any idea what that trans weighs alone?
Mike,
Aluminum case & tail housing goes about 100 lbs. Magnesium case & tail housing are 8 lbs. lighter. I had Paul @ Liberty Gears help me upgrade an old Doug-Nash 4+1 back in 2008 to Liberty`s face plate system legal for my 1985 M/S NHRA Stock Mustang and up-grade the shift shaft seals in the case. I know for Super Stock racer Terry Johnson who went to Liberty`s 5-speed and picked up .2 in his car and made it more fun to drive again. |
#8 | |
#9 | |
Liked 684 Times in 289 Posts
...4 speed only Last edited by Mike Jones; 11-05-2018 at 03:21 PM. |
You can run a 5 speed manual in stock if the vehicle came from the factory with a 5 or 6 speed manual. It just has to be clutch assisted, not clutchless in design.
