Liked 959 Times in 192 Posts
Looking for a block for my next 265 build.Which one was the best to use back in the day? Yes I know a Bow Tie would be the one to use,but the lottery hasn't paid me off yet.LOL. I've heard stories about the 57 block being a lot thicker in the deck area, so i'm looking around for one of those.I think it has a casting that number ends in 548 .
Liked 53 Times in 38 Posts
I got a 55 (265 3 speed) under 140 tons of dirt if you like digging. Of course it's been there 45 years
Thanks for the offer on the 55 block, but it is least desirable of the 265s.No oil filter that year. If it has a 4 bl intake I would be interested in that though.Casting number ends in 348.
Liked 330 Times in 178 Posts
1957 only ---265 block had thicker deck surfaces. Some say that if the engine serial number is still on the block then look for a letterC at the end that is "supposed" to signify a thicker deck surface
Liked 309 Times in 88 Posts
"C" is correct for '57 265, a 57 283 block would end with an "F".
Liked 162 Times in 45 Posts
In 1959 there were some replacement 265 motors built for trucks. They were truly 283 blocks not bored all the way, reat thick walls and a neoprene rear seal. We found one. Good luck!
