Old 01-07-2019, 10:59 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Re: make small hot tank
Heat makes chemistry work harder. Heated tanks are great. Buy your lye from a supplier as opposed to using drain cleaner. Not needing to be listed, don't know why, some lye based drain cleaners use heavy metals for a bigger kick, and are short lived. With a temp of 90+ try the Sam's club HD degreaser. Cheap and concentrated. If you plan on cleaning aluminum, lye and certain degreasers are a no-no.
House of Darts is offline   Reply With Quote
Old 01-08-2019, 09:47 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 881 Times in 236 Posts
Coleydog got it with the Red Devil lye ….cheap and effective.
I've been using it for years since machine shops have been getting rid of their old caustic hot tanks.
I use a large heavy duty 23 gallon storage tub with a bung installed on the side with an old oil pan heater element I had laying around in it .
I try to keep the temp around 175-80 and I have a tube thru the cover that I can hook up to the air hose to aerate the mix and keep it cleaning.
What ever you use for a container, if it's plastic make sure it will crush and deform , not crack .
Old 01-09-2019, 06:39 PM   #3
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
Lye to water ratio?
outlaw is offline   Reply With Quote
Old 01-09-2019, 10:51 PM   #4
House of Darts
Call a chemical supplier. Guessing on a concentration is not good. You are talking some real chemistry here. Over concentrated solutions are a pain to remove. Its not just a water rinse. You can force caustic salts into the pore of the metal and it will leach out over time, like into your cooling system or oil. Knowing the capacity of your tank and what you want to accomplish, i.e. degreasing, will allow the supplier to give you the concentrations and other tips. Depending upon how much you have in the tank, you may want a lid and an exhaust fan The warm mist travels thru the shop and contaminates everything Not being an alarmist, but good knowledge and safety goes a long way. Its simple when you get to know the works.SAFETY FIRST!
Old 01-10-2019, 01:28 AM   #5
Coleydog
Liked 53 Times in 38 Posts
All my tanks are outside, covered. My shop is to valuable to lose.
Get online, good help from people on how to set up any type you need, a lot of do's and dont's
Old 01-11-2019, 10:24 AM   #6
curtis reed
Liked 125 Times in 59 Posts
A good safe biodegradable cleaner is Oakite brand cleaners. We had a hot tank with their cleaner years ago. When we needed to change to fresh chemical we would mix it with soda ash to render it inert. Here is a list I found online of what they offer.
https://www.chemetallna.com/products...eralmaint.aspx
curtis reed is offline   Reply With Quote
Old 01-11-2019, 11:21 AM   #7
kansas stocker
Liked 249 Times in 48 Posts
The oakite products that I have used were all alkaline. I don't think soda ash, also an alkaline, would neutralize them. All I have ever used is the old powder. Probably have something new I'm not aware of.
Pete
kansas stocker is offline   Reply With Quote
