Liked 20 Times in 15 Posts
The block I run in mine is a 3720991(1956 number) but it has the neoprene rear main seal so it must have been a service replacement unit. No side mounts.
The '57 265 is a 3731548 and the number on the passenger side(on the pad in front of the head) can be either a "C,CD or CE". Mine is a "CD" which I believe meant it came with a 3 speed overdrive manual transmission. The car it came out was a 2 door wagon. I think "CE" meant heavy duty clutch. I call it a "Poor Man's" Bow Tie block. Crank is part #3735236. None of the 265's I own have side mounts. Last edited by 55 Chevy; 01-09-2019 at 05:33 PM. Reason: Bad Grammar |
