Old 01-28-2019, 10:37 AM   #1
Brian Oakes
Liked 439 Times in 116 Posts
Default Re: Flaming River Steering Box in a 69 Camaro
Mike are you sure you used a vega pittman arm, Vega,s are straight one's, Camaro's have a dip in them.
Brian Oakes is offline   Reply With Quote
Old 01-28-2019, 11:14 AM   #2
Hacksaw
Liked 314 Times in 177 Posts
Brian: I think the OEM Vega arm does have an offset and all the aftermarket ones are straight. ?????
Old 01-28-2019, 12:01 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
Yes. I used the straight one. I needed to lower the drag link to clear the oil pan. The straight pittman arm gave enough clearance. I did have to lower the idler arm on the opposite side to match. Then a bump steer kit to lower the tie rod end at the spindle to correct that geometry. Worked out pretty nice.
Mike Pearson 2485 SS
