Old 03-04-2019, 10:12 PM   #1
GTX JOHN
Default Re: question on rings ?
We have been lowering the Oil ring Tension for 50+ years and
it not difficult.
We run Gregg's Rings in all our Stock and Super Stock
racers.
I would not DREAM of doing the second ring myself!
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 03-06-2019, 12:01 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
If you want pictures of a fixture and a little info, let me know. You need an accurate lathe.
BTW: I have made low drag Napier rings for applications they were not available for.
Adger Smith (Former SS)
Old 03-06-2019, 10:55 AM   #3
Makinchips
Adger, please send ring and fixture info to igrinditshrp@aol.com.
Makinchips is offline   Reply With Quote
Old 03-06-2019, 12:00 PM   #4
joe cool
Liked 5 Times in 3 Posts
Thanks but I do not have a lathe. And yes , I can screw up things pretty quiclly . Suppose just a standard rebuild is in order. Thanks for all the advice fellas.
Joe Keightley
Pacific Junction Iowa
joe cool is offline   Reply With Quote
Old 03-07-2019, 11:03 AM   #5
kansas stocker
Liked 250 Times in 49 Posts
I think I've thought up plans for one but would rather see something that would sure work. Would appreciate it if you would put me on the list. Sent you a pm.
Thanks.
Pete
kansas stocker is offline   Reply With Quote
Old 03-07-2019, 12:29 PM   #6
Ed Wright
Ed Wright's Avatar
Napier style second rings help with oil control, and require less oil ring tension. Using a fish scale to measure drag, I've been down to 4.5lb drag, but got some blue smoke at times. 6 lbs seems to run just as fast, with no blue smoke. 4" bore.
Ed Wright 4156 SS/JA
Old 03-07-2019, 01:45 PM   #7
John Dinkel
Liked 265 Times in 69 Posts
Thumbs up Re: question on rings ?
Adger, I'm interested too. maxwedgejohn@aol.com
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 03-07-2019, 06:07 PM   #8
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: question on rings ?
If you're trying to get by cheap, just use correct size moly filled top ring with shim stock behind it to space ring close to edge fo ring land on piston. Use next undersize plain iron 2nd ring as is. Use next undersize oil ring expander with correct size oil rails. This works pretty good for cheap ring package on sbc.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 03-08-2019, 11:03 AM   #9
Dan Lattimore
Liked 154 Times in 37 Posts
123
66W30POST
Dan Lattimore is offline   Reply With Quote
