Old 03-21-2019, 10:05 AM   #1
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Default Re: Radial tire question
Thanks, Mike. I've never had that. I have a low hp car that always just dead hooks.
This is low hp as well around 750hp, with aim to dip in the 5's 1/8 N/A 23 sbc @3250 pds 10 x 28 bias tire. New combo just for fun, no particular class in mind. We kinda stumbled on using the wheelspeed to our advantage, first time we took it out went 6.01 on a set of ten year old tires. A lot of wheelspeed w /no wheelstand. Took it from there using shock adjustments favorable for wheelspeed on new tires to keep the car off the bumper no wheely bars.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 03-21-2019, 11:02 AM   #2
Ed Wright
Ed Wright's Avatar
Thing about radials on a stick car, stick cars usually need to turn the tires a little at launch. Radials don't "recover" like bias slicks. I was with a friend who had a fast Pro Stock car, when he decided to try to make radials work. Last I asked him about it, he never made them work. When radials spin, from what I have seen, they spin. Bias tires I have had recover much better.
Ed Wright 4156 SS/JA
Old 03-21-2019, 11:29 AM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
FWIW,a few years ago a friend was running a 305 stocker stick car.I let him try my Hoosier 9x30 radials.Had them at 15-16 psi.I run 20-22 on my auto.Made 2 runs hooked on both,picked up just under a tenth and almost 1 mph over his M/T bias.The track had good bite that day. gsa612
Old 03-21-2019, 11:52 AM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
When I did try this a few years ago, I had to run them down to 10-12 PSI, they didn't work at all at the normal 20 PSI range that the auto trans guys seem to run. Interestingly, I picked up nothing as far as ET goes which surprised me.
Jim Caughlin is offline   Reply With Quote
Old 03-21-2019, 12:29 PM   #5
gsa612
gsa612's Avatar
You would think at that low psi it would drive the rim into the ground making the tire oval,then unload on extension with the radial sidewall.You may have to change launch rpm and clutch settings and tighten the shocks for less "hit' to get it off the line clean.It would be more of a challenge on a higher HP combo. gsa612
Old 03-21-2019, 11:57 AM   #6
Coleydog
Liked 53 Times in 38 Posts
Not a stick guy but good reading and learning. Back in the 70s I would go to the track with a good friend who had a 64 Vette M/P 277 cu in. They had to spin the tires (14x32) at 10,000 + rpm or it would stand on the bumper. Not too much science in clutches back then. I imagine a dead hook with radials would rattle teeth and pull your eyes back around your head, and very hard on parts.
Mike
Old 03-21-2019, 12:36 PM   #7
Mike Rietow
Thing about radials on a stick car, stick cars usually need to turn thebtires a little at launch. Radials don't "recover" like bias slicks. I was with a friend who had a fast Pro Stock car, when he decided to try to make radials work. Last I asked him about it, he never made them work. When radials spin, from what I have seen, they spin. Bias tires I have had recover much better.
Someone will bridge the gap. They always do. It's essential-intrinsic.
Old 03-21-2019, 01:42 PM   #8
Jim Caughlin
Mike, not bashing your product but have you checked with NHRA about the legality of this for Stock & SS? The reason I ask is that I proposed something similar to this quite some time ago and was told absolutely not. They said that anything that affected the release of the clutch linkage would not be legal. I think their issue is that this kinda gets into the delay box gray area. Jim
Old 03-21-2019, 05:59 PM   #9
Mike Rietow
By-product- ramification of rolling up sleeves unambiguously, possibly. Unless new tire technology solves the equation. Although once that happens, it's no longer an advantage, dominion.
If you're referring to me.
Old 03-21-2019, 07:54 PM   #10
weedburner
Liked 20 Times in 16 Posts
If that question was intended for me, I have no idea if it's NHRA legal for stock or SS. It does not affect the manual release of the pedal with your foot, it only stops the pedal's return at a pre-determined point. Basically the same as adjusting base pressure, except that it also has a bleed that allows additional pressure to then come in at a much slower rate. That allows more slip during launch without blowing thru the clutch in high gear.
Here's a Psi graph showing what it does on a hyd throwout bearing. The vertical drop of the trace was all foot controlled. It's only after the clutch hits that pressure drop is controlled (acts on the pedal itself, also compatible with mechanical linkage)...
There's an article in the April issue of NMCA/NMRA's Fastest Street Car Magazine. I have not seen it yet, but I hear they interviewed some racers that are using it.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
