#11 |
Liked 132 Times in 27 Posts
I'd just set the timing at 3000 rpm as you get a few degrees of timing difference from idle to 3000 from distributor, cam/distributor gear clearances and cam end play.
#12 |
Liked 223 Times in 73 Posts
It's done, one small lock washer, probably for a #10 screw, fit perfectly. Did not noticeably increase the space between the two surfaces but was just enough to be able to tighten down firmly. No more movement at all.
#13 |
Liked 54 Times in 33 Posts
Between all of the allowable tolerances of the cam and dist. gear and the rubber band up front, (timing chain) you'll never remove all of the slop. But don't worry about it. When it's floored its tightened up.
#14 |
Agreed, when I said no more movement I meant in the centrifugal advance mechanism itself. There was no noticeable change in the gear clearance, and I didn't add to the shims.
#15 |
Back in the 70's, GM sold a pack of distributor shims. They were .010 or .015 maybe ?
Ten to a pack , and it would take about half of them to shim up a distributor gear to remove most of the play there. Always wondered why they left them that loose . GM must have seen as a hi-po issue, or they wouldn't have sold them. I wonder if they are still available or somebody has them as NOS ?
#16 |
Liked 53 Times in 38 Posts
I always use one very light spring on the advance. Engine starts at a small degree then flings out after 500 rpm to full advance. Easy to start any high compression engine. Also use a locking collar to allow no shaft up and down movement. I use a stock dist except when needing a tach drive.
Mike |
#17 |
Liked 28 Times in 15 Posts
I thought the Summit brand distributors like the ready to run type were MSD. I found a pack of Moroso brand distributor shims at a speed shop a few months ago.
#18 |
I've been building distributors for 30 years, and no longer can find shim kits. If anyone knows please share. Thanks.
#19 |
Liked 759 Times in 379 Posts
This^^^ I would never recommend a locked out distributor when using a stock or stock type distributor. I’ve been running my distributors with 18-20 degrees mechanical advance and all in by 2000 rpm for 25 years. The reward is no hard starting, no kickbacks, no broken flexplate teeth and no broken starter drives. Spins over like the plugs are out.
#20 | |
Liked 22 Times in 14 Posts
https://www.competitionproducts.com/.../#.XOEV0aR7mUk Rick Thomason GTOMayhem |
