Old 05-20-2019, 10:55 PM   #1
SST159
Liked 20 Times in 16 Posts
Default Re: Motor Home RV House batteries
You are right. I forgot about the micro wave clock.
I am sure that will draw something.
Next time I do a test i will unplug it to be sure but I bet that is it.
regardless .25 amp draw is not going to make that much of a difference.
Soooo I am thinking the AGM is not the way to go. That leads me to either going back to two12v deep cycle or two 6V golf cart batteries.
unfortunately I may not have enough compartment height for the 6V.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 05-30-2019, 02:21 PM   #2
G Anderson
Liked 4 Times in 3 Posts
The 6Volt GC batteries are definitely the way to go !!! (best bang for the buck)unless you want to spring for Lithium ---they do require maintenance- but the ones in my MH were new in the fall of 2012---I do equalize them once a year BTW--- 2) 6V GC batteries are appx. equivalent to 3) 12V Maintenance Free in Amp Hours
G Anderson is offline   Reply With Quote
