#1 | |
Liked 173 Times in 52 Posts
Then I moved to the front which I hadn’t touched except for a 90/10 strut. Loosened up the bushings changed the caster camber plates to give more movement, then the car started to rotate a little. Launch is fairly even. Shock settings are critical as noted. I have Air bags new in the box for sale. Slo Mo video taken with an iPhone. Left Right Kelly |
Liked 101 Times in 52 Posts
Robbie,
Remember whatever preload you place back there for launch will transfer to the opposite front corner on braking. All good suggestions. The air bag is probably the quickest and cheapest way to try something. I like the bar. |
Liked 160 Times in 51 Posts
Airbag RR #25-#35 air pressure. Good to go. It works fine for under 400hp. All I had in my SS'er that goes 11:50s
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
Liked 10,851 Times in 2,254 Posts
I have never observed the wheel changing speed up and down on the launch like it did in the right hand slow mo. Was it to much psi or not enough?
Liked 118 Times in 41 Posts
I think i and going to try air bags on both sides running more pressure on the right side. Cheap fix at under $100,
I noticed in the video that the T-bird did not drop in the rear at all. Doesn't a T-bird use the same set up as a mustang in the rear?
U/SA 79 Mustang |
Same as a T-bird 78 to 88 I believe. My car didn’t squat much until I softened the compression on the shocks.
Liked 370 Times in 101 Posts
Has anyone tried these ?
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#8 | |
Liked 358 Times in 83 Posts
Back when dinosaurs roamed the earth, guys who raced coil spring rear suspension cars (I'm thinking about 60s Chevelles) just installed an Air Lift airbag in the right side spring, inflated it to the minimum psi required to kill the roll rotation and all was right with the world. Worked like a charm, was way cheap and didn't have any real effect on anything but the problem. |
Liked 184 Times in 113 Posts
In my 1969 Impala Stocker.
Used Airbags and glued a piece of 2by4 on axle housing. On launch it hit the pinion snubber. |
#10 | |
Always something! |
