Old 08-09-2019, 10:06 PM   #1
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
Default Re: 12V racing battery recommendations
Been running odessey for the last 8 years never had any problem and they are not expensive
mat H/SA is offline   Reply With Quote
Old 08-10-2019, 06:51 AM   #2
Liked 10,816 Times in 2,248 Posts
I have used two 11.5 lbs Braille battery's for years in the six pack car with zero let downs. Once the starter acted a little slow, battery was ok just a loose cable. My alternator works. I have tested and could go three rounds without charging in between rounds. I did cool car with sprayer until temp was reached then turn off fan. I change them out every three years.
Old 08-10-2019, 11:54 AM   #3
cyclonebfx
Liked 5 Times in 2 Posts
I used to run the optima batteries because they would last forever but they weigh a ton! Recently switched to the Odyssey batteries and have been really happy so far.
5705 F/S
5706 D/SA
cyclonebfx is offline   Reply With Quote
Old 08-15-2019, 04:49 PM   #4
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Sounds like you and I have exactly the same battery experience, Larry. This is the 4th season on my two 11.5 lb Braille batteries. I even completely killed them once last year by leaving the water pump on for 5 hours...discovered this fact when they called us up for first round. Charged them for 15 minutes or so, the car started, and I still beat a few people to the lanes.
Paul Merolla is offline   Reply With Quote
Old 08-16-2019, 10:43 AM   #5
btrc
Liked 84 Times in 42 Posts
A few years ago my car wouldn't start for the semi finals at a race and I decided that this was not going to happen again.
Now between rounds I run the fan and water pump from the (2) deep cycle batteries in the trailer normally for the winch and jack. I run 4 ga cables to a switch box and then 4 way cable to a 4 pole plug. The 4 way socket in the car is wired in parallel to the normal wires.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 08-16-2019, 08:52 PM   #6
cmracing
Liked 62 Times in 29 Posts
Made 13 passes Saturday with a single Group 31 in the trunk, 105amp GM alternator supplying the juice, never had my charger out. Doubt there are many cars using as much power as mine:
Dual stock GM F-Body fans, over 20 amps each.
Mezier electric water pump.
Weldon EFI fuel pump.
8 injectors, though they take very little.
4 coil packs (DIS waste fire setup, like a GN).
The last two hours ran the electric fan on the 2nd trans cooler, not sure what it draws.
The last 6 passes were made 15 minutes between each, only got to the trailer for fuel.
So....... Why mess with these little batteries you have to worry about charging when there are massive batteries out there that will never give you an issue?
cmracing is offline   Reply With Quote
Old 08-17-2019, 03:23 AM   #7
GTX JOHN
I run one or two Walmart budget batteries (either 26 or 56 as I recall)
that weigh 26 Lbs. I have been for 25 years. Easy to exchange on the
road if needed. They have recently gone up to $49.95.
I do charge them in the latter rounds.
John Irving
741 Stock
741 Super Stock
Old 08-17-2019, 10:27 AM   #8
Paul Merolla
Because in Stock, we have to keep the battery in the stock location...a group 31 on the nose of the car wouldn't be too smart.
Old 08-17-2019, 03:41 PM   #9
cmracing
I understand that. I have wired Stockers and kept a small battery up front to meet the rule, and put a real battery in the back that I never had to worry about. You're right, I can't imagine a Group 31 under the hood of anything but a truck!
Old 08-25-2019, 08:07 PM   #10
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Paul do u have to use their charger?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
