Old 09-15-2019, 11:35 AM   #28
Painter
Liked 162 Times in 45 Posts
Default Re: ONAN Marquis Gold 7000 Gas
I have a 10kw diesel that has the belt issue. 500 hours is the max I have gotten. O-no dealer says it should 1000. Have used O-nos way overpriced belt and Gates and Dayco- very similar results. I believe the belts fail because the air flows thru the radiator then over the hot engine before it reaches the belt. I think this very hot air flowing over the belt causes the failures. I have installed an extra fan blowing air into the radiator to hopefully reduce the temperature of the air flowing across the belt.
Painter is offline   Reply With Quote
