Old 10-06-2019, 08:17 AM   #1
00SSCamaroZ
Liked 11 Times in 4 Posts
Default Re: Engine diapers on S/SS?
Originally Posted by Doug Walker View Post
Are you referring to this ?? Blue Camaro was in the left lane. Debris was in the right lane, but may have originated from either car.
Does not look like 1969 Camaro to me, but maybe more than one car pitched its safety gear off mid track.
First time I'd ever seen this happen.
That looks like it. Thought it was a 69. Obviously not. Guess I am not a good eye witness.
Mike Z
00SSCamaroZ is offline   Reply With Quote
Old 10-06-2019, 09:38 AM   #2
rboyle
rboyle's Avatar
Liked 602 Times in 165 Posts
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
Old 10-07-2019, 07:07 AM   #3
Liked 10,965 Times in 2,260 Posts
After looking at the B-E body engine, steering, and headers on my stocker, it would be a lot of work and expense. The drag link runs real close to the sump and the bottom of pan, this could be a potential crash if the Kevlar blanket jams the steering. A motor plate would not help the steering situation. A tray might work until a big wheel stand. When that happens on my car it bends the oil pan against the pickup, and bends the transmission pan. The oil pan I have to fix before I make the next run. If new ss headers are needed to complete the ORD I will be done.
All of a sudden cutting bait doesn't look so bad.
Old 10-07-2019, 10:35 AM   #4
Steve Stasko
Liked 292 Times in 147 Posts
I must have done something wrong on my '64 Dodge when I put the engine diaper on it. I have the factory K-frame, steering, and torsion bars. Using 1 3/4" Hooker S/C headers (one tube through fenderwell). I fit a universal Jeg's diaper on the car without issue, though I did have to get creative with some of the mounting points for the support straps to hold it up.
I wasn't real fond of putting it on, but when the rules require it (I ran the car in S/ST a few times...ex-SS car), you find a way to make it work if you want to race.
While the Jeg's diaper doesn't provide the best fit, I can only imagine how much better the job would have been had I used something that was designed for the car.
Old 10-08-2019, 01:42 PM   #5
Don't have a dog in this hunt, but never stopped me before.
Steve, I don't have a rule book, but are you saying that S/ST, the entry level class, where the index is only 10.90, requires a diaper?
Old 10-08-2019, 02:45 PM   #6
jmcarter
jmcarter's Avatar
Liked 3,238 Times in 985 Posts
Mark, yes an oil retention device is required in Super Street. Believe it would already be in place but the last time they floated it the heard how much of an impact it would be. Strangely enough bracket cars don’t require, likely because they don’t put the Fuel Circus at risk of losing any track time. I’ve already submitted my impact statement to the SRAC. Have a Stefs pan with hole for the drag link to travel through, custom made headers by REF that come very close to pan in several places. Even if one could be custom made it would come very close to the belt drive. As stated earlier if they hand down the rule as mandatory then current car will no longer run in Super Stock
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-08-2019, 11:20 PM   #7
Steve Stasko
Correct...that and the flywheel shield were the only two things I had to add to the car for S/ST. I know a lot of tracks were requiring a diaper on Sub-10 second cars as well for their weekly bracket programs. I don't know if I needed the flywheel shield though as the car runs less than 135 mph?
I don't think the diaper should be mandatory...but it's definitely cheap insurance.
For what it's worth...The rulebook does state that a minimal number of slots or holes to "clear frame, steering, or lines" is permitted.
Old 10-09-2019, 01:05 AM   #8
Well guys, There's a way to address the S/ST issue.
No electronic throttle stops , and a 125 max speed (breakout).
In other words, bring it back to entry level.
But why in the hell would they?
Look what they've allowed to happen to Stock.
Old 10-07-2019, 10:48 AM   #9
B Parker
Liked 2,343 Times in 465 Posts
Larry I love your pink car. And I'm jealous of all the races you get to go to. But if you were to cut bait could Patsy still go and report. Class racing would not be the same without her. Barry
Old 10-07-2019, 11:12 AM   #10
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Engine diapers on S/SS?
Excessive RPM's will do it every time. Now you have solid lifters to go along with the killer valve springs and excessive duration cams and roller rockers, etc. ! What else would you expect unless you spend several thousand more dollars to build modified and S/S wanna be engines. You get what you wanted !
