Old 12-09-2019, 04:53 PM   #1
Teddy
Default Mid plate Stick car
What are you guys using for a midplate on a stick shift car? I’ve got a front motor plate that bolts up no problem. Finding a company that makes a mid plate for a clutch equipped fox body mustang isn’t very easy. Thanks for the help in advance 😎
Teddy is offline   Reply With Quote
Old 12-09-2019, 05:31 PM   #2
Jeff Swanson
Liked 62 Times in 21 Posts
Default Re: Mid plate Stick car
Try skinnykidracecars.com, they make quite a few configurations depending on your combo.
Jeff Swanson is offline   Reply With Quote
Old 12-09-2019, 05:34 PM   #3
lca1971
lca1971's Avatar
Liked 3 Times in 2 Posts
You could make your own. Use the bell for your bolt pattern and weld tabs to your chassis. Use card board to fit everything then, transfer to 1/4 aluminum plate, or 1/8 steel plate and you've got a mid plate. If youre not into making one any of the chassis companies offer mid plates.
lca1971 is offline   Reply With Quote
Old 12-09-2019, 06:34 PM   #4
Teddy
Problem is, all the chassis companies make mid plates for automatic equipped cars. With a clutch it has to be a solid midplate. Only a hole in the center for the crankshaft.
Old 12-09-2019, 06:58 PM   #5
rx dealer
Liked 53 Times in 13 Posts
I did not run a mid plate. I had steel tubing about 1/2 inch in diameter, with hiem joints on each end. one end went to the trans cross member and the other end on the clutch can. this was hooked up on the passenger side of the car. it's simple and rock solid. Luke
rx dealer is offline   Reply With Quote
Old 12-09-2019, 07:14 PM   #6
Jim Caughlin
Liked 805 Times in 245 Posts
I built a tube cross member that bolts to the frame and the flange on the bellhousing. I'm happy I did because I had a flywheel come apart a few years ago, it broke the back of the block off, the crossmember held everything together until I got the car stopped.
Jim Caughlin
SS 6019
Jim Caughlin is online now   Reply With Quote
Old 12-11-2019, 11:28 AM   #7
lca1971
lca1971's Avatar
Yes, several different ways you can do it. It also depends on where the eng and trans bolt together in relationship to the firewall.
Old 12-11-2019, 11:30 AM   #8
lca1971
lca1971's Avatar
Pictures?!?
Old 12-13-2019, 05:53 AM   #9
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Quick dumb question..mid plates are not allowed in Stock?....correct?
Will Lamprecht
1965 Impala I/S
Old 12-13-2019, 08:10 AM   #10
Liked 10,786 Times in 2,242 Posts
Correct
