Old 03-17-2020, 03:57 PM   #13
carbuilder
Liked 19 Times in 5 Posts
Default Re: Calvert split mono leaf springs?
all the spring does is hold the car up off the ground,,,a leaf spring is a leaf spring,,,however,,,if a spring is too stiff,,as in a multi leaf spring,,,thats where the problem begins. You always want to use the weakest spring that will suspend the car. If a mono wont hold up a heavy car,,,,then look at removing leaves from a multi leaf. If the spring is to stiff,,,, no shock adjustment,pinion angle change is going to overcome the stiff spring,,,,ask me how I know,,,,,just kidding,,,,dont ask
carbuilder is offline   Reply With Quote
