Old 04-27-2020, 02:05 PM   #11
FED 387
Liked 333 Times in 180 Posts
Default Re: stock class rear axle?
9 inch only on COPO -Cobra Jet and Drag pac is the way I understand it--I think NHRA had a post on what vehicles can use a 9 inch-FED 387
Old 04-27-2020, 02:29 PM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
modern parts in 12 bolt will be great in there....
pro gear absolutely a must with ANY stick even a W car..... and correctly setup if it isn't you won't get a season out of it... Randall was going through a set of gears a season on his truck... I set them up and he has 6 years on them now...
knock on wood…. I have never hurt a gear or anything in my K/S car... gear has at least 300 runs.... spool, steel caps, 35 spline axle, chrome moly tubes,5/8 wheel studs all Mark Williams parts, I installed the tubes and caps and built the rest...
Old 04-27-2020, 09:30 PM   #13
GUMP
Liked 2,359 Times in 557 Posts
A 9 inch is legal in any 2008 and newer car.
GUMP is online now   Reply With Quote
Old 04-28-2020, 01:32 PM   #14
Lyn Smith
Liked 995 Times in 200 Posts
Saw a 69 Camaro Stocker a few years ago with a 57-64 Pontiac r end in it at a Div. 3 Points race after any GM rearends were oked. They must have changed the ruling. Ford rearends are ok in certain years though????
Lyn Smith is online now   Reply With Quote
Old 04-28-2020, 03:23 PM   #15
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Last I knew Olds was still General Motors.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 04-28-2020, 07:26 PM   #16
MR DERBY CITY
Liked 8,114 Times in 1,531 Posts
That’s what I was thinking. ....Are you positively sure of that YAK ?
Old 04-28-2020, 08:06 PM   #17
jmantle
Liked 172 Times in 81 Posts
Doesn't make sense considering I was told I could run an 8 3/4 Mopar or a Dana 60 in an AMC (which I thought was a stretch).
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 04-28-2020, 09:37 PM   #18
What I am sure of is lots of Jr. Stockers would have loved to use a P/O rear, but instead, they went through untold grief with Chevy "P" cases and all that junk.
The Pontiac/ Olds setup was common in the M/P and Gas classes.
If the rulebook still says "of the same manufacturer" , NHRA always took that to mean Chevy, one , Pontiac ,two , and different.
Now, if it says something about "corporate" , then you boys may have an argument.
But then again, it seems they have already spoken on this, many years ago.
Old 04-29-2020, 06:30 AM   #19
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Email from Tech Director 1/29/2020:
You are not allowed to use any rear end housing under your car other than a Chevrolet housing. It can be a 10 bolt, 12 bolt etc., but must be a Chevy housing.
XSTOCKER is offline   Reply With Quote
Old 04-29-2020, 10:12 AM   #20
MR DERBY CITY
There you go, Thank You for the clarification Mr X.......
