Old 05-10-2020, 11:36 AM   #1
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Re: two step rev limit max for foot brake automatic
I usually have the two step set at 3000 or 3200. Mine is a trans brake, but when I foot braked it on the two step it was the same rpm. But I think I could have gone up to 4500. My understanding is higher rpm will lower reaction time, but won't change the et or 60 ft. But your results my vary.
Patric Fox is offline   Reply With Quote
Old 05-10-2020, 07:45 PM   #2
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
I have my pressure switch set to come off at about 850. Staging with comfortable force on the pedal gives me about 1150-1200 psi in the rear line, I vary the rpm between 32-3600 typically, but have gone to 4000. This is with a converter the flashes 5400, and single rear wilwood 4 piston calipers. I do have some sort of special pad but I can't remember the brand, they were supposed to be more aggressive holding than a normal pad.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 05-10-2020, 08:52 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
so i dont have the top end brake pressure switch (yet) , but have my switch set at 900 psi with adjustment that i can easily change ,, this just this a garage test ,,,, i will test it once the car is moving on its own ,, (next week maybe )
thanks for your input,, cant wait to peal !
